LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Appearance & Detailing (https://ls1tech.com/forums/appearance-detailing-18/)
-   -   Need Help: Horn won't stop blowing (https://ls1tech.com/forums/appearance-detailing/10937-need-help-horn-wont-stop-blowing.html)
Craig98WS6 Apr 23, 2002 05:03 PM
Today I used my key fob to open my car as usual (horn set to blow when unlocked) and the horn started blowing. At first it was on off than solid on. I put the key in the ignition and it stopped for a minute and then started again. I removed the fuse and all seems well except of course the horn does not work. I disconnected the motion sensor near the spare tire but that did not correct the problem.
I was thinking maybe the horn relay is sticking. Anyone know where the relay is located?
Thanks-Craig
<small>[ April 23, 2002, 05:04 PM: Message edited by: Craig98WS6 ]</small>
WILWAXU Apr 23, 2002 05:31 PM
Re: Need Help: Horn won't stop blowing
Sounds like a freaked out alarm system...
This is a good one for the electronics section..
© 2026 MH Sub I, LLC dba Internet Brands
