LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Appearance & Detailing (https://ls1tech.com/forums/appearance-detailing-18/)
-   -   Oem hid's (https://ls1tech.com/forums/appearance-detailing/1237632-oem-hids.html)
Bay Area Y2K_Z28 Feb 6, 2010 06:48 PM
Oem hid's
Would oem hid"s from a newer vette work on my 2000 z28? or how about other stock hid's from a escalade, lexus rx400 ect.?:confused:
Blackbirdws6 Feb 6, 2010 07:06 PM
They could but you would need an adapter harness to convert to the HID components of the oem vehicles. Additionally, you non hid factory housing will not accept a oem hid lamp.
Bay Area Y2K_Z28 Feb 6, 2010 08:51 PM
would the hid lamps fit into those projector headlights they sell on ebay with the halos?
FTHISinc Feb 6, 2010 09:02 PM
No they won't fit into those projector housings. There are a couple different ways you could accommodate an OEM style HID bulb into a camaro headlight housing.
A) Silicone those bitches in there (not recommended)
B) Buy a set of projectors that fit the bulb, and retrofit the projector into the housing (check HIDplanet.com)
You'll also have to build or buy a custom wiring harness that will plug into your stock bulb connectors and have a ground along with a positive battery connection. A lot of the guys on hidplanet.com will build you a custom wiring harness for a price .
If just want HIDs, check sponsors or ebay.
SparkyJJO Feb 6, 2010 10:19 PM
The projectors on ebay use either an H3 ("ok" light output) or H1 (much better output) bulb. So to use those, you'd just get an H3 or H1 retrofit kit. I have H1 projectors in my car, with an H1 retrofit kit, and it has been working flawlessly for well over a year.
FTHISinc Feb 6, 2010 11:34 PM
h3 projectors are basically fog light projectors...great for headlights...not
Bay Area Y2K_Z28 Feb 7, 2010 06:35 PM
Thanks guys :)
i just don't want a cheap set that id go out on me soon... & i like how on the factory hid's change color as they're coming at you
Blackbirdws6 Feb 7, 2010 07:04 PM
Originally Posted by Bay Area Y2K_Z28 (Post 12861092)
Thanks guys :)
OEM hids are certainly going to be more reliable than a kit however there are some good kits out there with decent reputations.
The color change you see from the oem stuff is simply the cutoff from the factory projector. Some aftermarket projectors will give you this effect are you go past the cutoff point.
Bay Area Y2K_Z28 Feb 7, 2010 09:06 PM
oh ok, what do you mean by cutoff? do you know of any good aftermarket projectors with this effect?
© 2026 MH Sub I, LLC dba Internet Brands
