cleaning up my engine bay(filling holes/paint)
hey, figured i'd post up some pics. it was sleeting out this morning so i pulled the Z in the garage and started to weld up the holes in the engine bay. i had already done the wire mods on both sides so i filled all them and some of the holes for the grounds. i just got them welded and ground down so far. ill hopefully get them all bondoed up today.
what do guys think, any other spots i should do before i start to bondo it? im also gonna make a cover to go over where the fuses were
got it all bondoed up, next will be priming it. i also pulled the fenders and bumper off. they are def getting repainted, the whole car might be, im not positive yet but im thinkin im gonna just do everything
a96ws6, ill get you some pics in a little bit, the fuses are just stuffed in that whole under where they sit and then im makin a cover for them
LOL wow didn't know that......when you're done, be sure to get some lexan and cut it to fit over the fuse box hole...it hides all that mess of wiring. It's very easy to do. I also opted to remove the brace that holds the fuse bos holder thing. It is spot welded to the tower.
