View Poll Results: What Type of Wax Do You Use
Paste
21
35.00%
Liquid
41
68.33%
Multiple Choice Poll. Voters: 60. You may not vote on this poll
What kind of Wax do you use?
if you apply a coat of (paste) wax over a previous coat (paste) , does it do anything like bring the shine out more or does it just add another layer of protection?
ive found the color of your car really plays a part in the best wax to use for it. i usually buy a different wax product every couple of months just cuz im bored at walmart
im starting to do that now lol gone through 3 different types of waxes so far, right now im using the meguiars cleaner wax, but im looking to also apply gold class as well
how long do you guys let the wax sit until you take it off ? somewhere i saw that someone let the wax sit on the car for 24 hrs before he wiped it off, does that help at all?
for the guys who are lookig for an over the counter product, available locally....i would suggest the megs professional # 26 yellow yech wax.....provides longer protection than the gold class / nxt
also, you can try to locate a local harley dealer....they should sell s100 which is the same thing as P21s
i used clearkote's carnauba moose wax.....and wolfgang's concours paint sealant
"cure" time depends on the product...............i usually leave the wolfgang on for at least on hour....air temp and surface temp play a big role as well
only real way to tell is to remove some of the last step product and see if it smears....if it does then leave it "cure" longer
i just bought megs swirl x, as well as nxt 2.0. now what order should i apply it in.
the order i usually use is:
wash
dry
paint cleaner
paint polish
cleaner wax
megs gold class wax
im unsure where to add the swirl x into the mix?
wash
dry
paint cleaner
paint polish
cleaner wax
megs gold class wax
#36
I like the durability and look of sealants.
My favorite go to combo is 2 coats of Duragloss TPP (105) to seal after cutting and polishing and topping that with 2 coats of Duragloss CCP (111). Drying with a coat of Aquawax between each wash and then reapplying one coat of 111 about every 7-10 washes.
