how to get led turn signals to blink
I recently put it clear lenses and led turn signals and then the arrow and leds would stay solid and not flash. Simple fix. Switch your turn signal flasher with your hazard flasher. Both are under the steering column under the 4 bolt cover. one is on the left on one is on the right. Just switch then. Works great now. Hope I help someone save some time and money.
no it works with no money spent
I dont need to buy any flasher. All you do is swap your turn signal fasher with your hazard flasher. Then your leds turns work and your hazards still work. The clicking when your blinker is on is also a little quieter, that tic toc noise always buged me but now just a little softer. hope this helps
