AFR gauge illumination wiring
hey guys i just got the new Innovate MTXL wideband guage kit. was looking at the directions for the backlighting. all it says is to connect the white wire to a headlight power wire and not a headlight dimming wire. where the hell can i find this wire?!
red wire, 12v power, is going to fuse box drives side IGN slot with a fusable link
black wire im running for a ground with my linelock under the center console
white wire shall be ran.......WHERE???
any help is appreciated! thanks
When I wired my Autometer gauges for illumination power, I just picked up power off of the headlight switch wiring. That way when I turned my parking lights/headlights on, the gauges would light up with everything else
If you have a test light, just probe the wires and determine which wires have constant power and which one is an accessory hot when you turn the parking lights on
