Do they make Hid's for 02 TA?
Old Mar 7, 2011 | 01:16 AM
marco93L's Avatar
Default Do they make Hid's for 02 TA?
I have a light burnt out on the ta and I went to the store to buy the SilverStars, and they dont make them. So, since I cant buy the SilverStars, is there a HID kit that is good for the trans am's?
Thanks
Old Mar 7, 2011 | 01:20 AM
dkbmxer002's Avatar
no.
but they do make Hid's for 02 TA's.
Old Mar 7, 2011 | 01:23 AM
Raven02TA's Avatar
see post# 9 for lighting differences.
http://www.f-bodyhideout.com/forums/...w-beams...done!
for the lows be sure you have a conversion housing if you have a T/A otherwise you wont be able to do it. i recommend the housing from LMC truck.
heres the way i went about it:
Here are the links:
Order the low beam headlight housings from this website. (part number 36-0302)
http://www.lmctruck.com/icatalog/cd/full.aspx?Page=65
if you want high beams too order this part number
36-0303=hi beam
order the fog lights and low beam bulbs/ballasts from here.
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
when you order the bulbs. you want
880 bulbs for your fog lights
and 9006 bulbs for your low beam headlights.
9005 for high beams if you choose to do them
be sure to order all bulbs in 35w
choose your color (ranging from 1000Kto 12000K)
you DO NOT need an HID harness. and you DO NOT need error code eliminators
thats it. other wise. plug and play (it wont actually be a plug. it will be 2 spade connectors on the wire. just push them into your pigtail for the lights. blue is hot black is ground.
Old Mar 7, 2011 | 10:59 AM
bigairboarder44's Avatar
Also, he is a sponsor here: http://www.blackbirdlighting.com/98-02.php
