what is needed to swap from 110 mph to 150 mph gauges?
I have a 94 m6 Formula and it came with 110 mph gauges. I want to swap to 150 mph gauges. What do you need to make it work and be accurate?
A cluster and a tune?
Will a cluster from a 97 and up Firebird fit, or do I have to get a 93-96 cluster?
I searched around for a while and couldn't get a clear answer so if someone could shed some light on the subject it would be greatly appreciated.
So a ls1 cluster is digital and a lt1 is analog.
If I wanted to use the digital cluster how would I make it work? Swap the analog odometer onto the new cluster?
I don't want to install it unless I can get everything to work correctly, and if the newer cluster is not easy to convert to work, then I will just use a LT1 150 mph cluster.
Will I need a tune to get the gauges to read right after swapping from 110 to 150?
You need a 94-96 150MPH cluster. It just plugs in and everything should work. You need to have the odometer re-set to the mileage of the vehicle chassis, otherwise it's a federal offense.
93, 97, 98, and 99-02 styles will not work for you. Each one of those is different than the 94-96 clusters and each other.
Okay so I need a 94-96 150mph cluster. My car has about 74,000 miles so it might be kind of hard to find a cluster with about the same miles. I looked on ebay and every cluster I saw was 140,000 miles or more.
If anyone has one let me know.
