Found a LED flasher that works and is cheap
Thanks! Just ordered two.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=130348033861
1 Post
Amazon.com: CEC Industries EF32RL Electronic Turn Signal Flasher Relay, LED Compatible, 2 + Ground Wire Prongs, 12 Volts: Automotive
If I go 4 LEDs in the back for brake lights
Keep it Clean flasher does not work with all LED
I will now try the CEC Industries EF32RL two pin flasher with a third ground wire.
#32
Sos
So I just did all LED on my 02 WS6, front blinkers, side markers, and rear tails. Left blinker operates flawlessly but when I do the right it makes all my lights flash, all four blinkers, fogs, tails, side markers, even my dash and radio. I have the 552 Keep-It-Cool flasher ques. Are the flasher ques the problem? Any help is needed and greatly appreciated!
#34
I received the two ef32rl(one for blinkers one for hazards) wed got them installed this morning and glad to say they work awesome noise is just as loud as factory blink just fine hazards work as well for those who wonder what leds im using autozone(my work) just got in a new line of tower styled leds(red,amber,white) in the most popular bulbs(3157/6,1156/7,168/194) anyways there not to bad expensive and the light output is great no hot spots and yes the leds are in an 86 iroc but every last piece of the wiring harness interior/exterior is all from a 00 t/a
#35
I just received the CF12ANL-01LED flasher from SuperBrightLED.com and still doing the same thing. Why is it turn all the lights and the dash and siders and everything on? That's where it has me most puzzled. I even put the stock flashers back in and the left blinker hang open like it should nc or to little resistance but the right does actually pop bc all the light's are supplying enough resistance to pop it I'm assuming. Help.
#36
<<<@!1!@>>>
im going to say because its like the 552 and ef12 its just a flasher probably a more heavy duty one put it still only has the two prongs as where the ef32rl has the two prongs as well as a ground wire i plugged my two ef32rl's in didnt work till i wired its ground heres the link to ebay where i bought mine great seller to
http://www.ebay.com/itm/400740074640?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
#37
1 Post
<<<@!1!@>>>
2 Prong Electronic LED Compatible Turn Signal Flasher Relay EF32RL Round 25 Amp | eBay
#38
Yes they'll work as a regular flasher. I've discovered the flashers weren't causing any of the issues I was experiencing. It was just a buld. Moved a few and replaced one and now all is good. So for ***** and giggles I tried the original 552's I bought, then the EF12', and lastly the EF32RL's and they all work properly. I will be doing the sequential next, just dont believe it will be possible to adjust the speed as the electronic flashes are going to flash at the same rate.
#39
1 Post
Doesn't the newer mustangs have sequential LED taillights? Would they have a flasher that we could modify to use?
