What size torx wrench does it take to get the Firebird seatbelt off?
Old 01-01-2012, 05:38 PM
FSUNole17's Avatar
Default What size torx wrench does it take to get the Firebird seatbelt off?
I am having to replace the little loop around the headrest that holds the seatbelt back and I need to remove the seatbelt to do this. Just wanted to know what size to use before I go buy one. Thanks
Old 01-01-2012, 06:18 PM
sweetbmxrider's Avatar
T50 but a T47 may fit better.
Old 01-01-2012, 08:55 PM
HotWhipT/A's Avatar
Old 01-02-2012, 01:29 AM
bill12690's Avatar
I used a T50 today on mine, its a camaro but should be the same I'd think.
well, actually...for the front seatbelts I don't think the T50 fit, I believe I had to use the T47. I did use a T50 for the rear seat bolts (on the sides)
Old 01-02-2012, 01:40 AM
Super-Bat's Avatar
It seems to vary, not sure if because previous owners mixed up the bolts or what, but in my bird it was a T47, but in a Trans Am I worked on it was a T50.
Regardless, it's usually smart to buy a "set" versus individually anyway, so you'll be covered when you go and buy your bits.
Old 01-02-2012, 02:48 AM
Ballinonabudget's Avatar
I used a damn vice grips
Old 09-20-2015, 04:20 PM
5.7stroker's Avatar
It is a T47.... which autozone had. To design it to accept a T45 or a T50 would make too much sense.
Quick Reply: What size torx wrench does it take to get the Firebird seatbelt off?
