LED's in HVAC knobs
Old Feb 3, 2012 | 06:26 PM
1fastls1ss's Avatar
Default LED's in HVAC *****
Well I got bored and always wanted my HVAC ***** to light up bright white like the newer cars. So I used some white LED's that I had and put them inside the ***** of the HVAC controls. First I removed the HVAC out of the car and took it apart. I then figured how to place the LED's in the ***** and used my soldering iron to melt two channels on either side of the ***** center to lay the wires into.
[IMG][/IMG]
[IMG][/IMG]
Ran the wires through the HVAC housing and out the back (the middle section cold/hot a small hole needs to be drilled to feed the wire through).
[IMG][/IMG]
Then soldered them together and put a resistor on the + wire. Tested it first with a 9V battery to make sure all worked well, and turned the ***** so the wires would not be to tight and have some movement when you use the *****.
[IMG][/IMG]
[IMG][/IMG]
Put it all back into the car and wired it into the plug for the HVAC lights from the car so the ***** would turn on when the lights come on. Put the radio bezel back on and done. Here is the final pic in the car.
[IMG][/IMG]
Next I'm gonna put an LED in the headlight switch, but ran out of time tonight. It would have been much easier if I didn't have to solder the wiring to the LED's, but overall it was pretty simple.
Old Feb 3, 2012 | 09:01 PM
whytryz28's Avatar
Found what I'm doing tomorrow.
Old Feb 4, 2012 | 12:14 AM
The Guz's Avatar
Nicely done. That looks good.
Old Feb 4, 2012 | 12:24 AM
camaroboricua's Avatar
That looks awesome! I have to fix mine. it doesnt light up at all.....Wonder if this will work on the T/A's also...
transambrotha's Avatar
looks awesome, good idea
Old Feb 4, 2012 | 12:39 AM
Tyler Z28's Avatar
nice work.
LS1121's Avatar
I don't get it? Mine have always lit up from the factory. I put red led's in my HVAC and now they light up red.
Old Feb 4, 2012 | 02:00 AM
TPI TERROR's Avatar
Nicely done will be doing this
Old Feb 4, 2012 | 07:41 AM
cancam99ss's Avatar
I like
Old Feb 4, 2012 | 12:54 PM
Swiat34's Avatar
You've just completed a project I've had my mind on for 2 years! Great job!
Old Feb 4, 2012 | 01:48 PM
MynameisLee's Avatar
That's badass, don't forget to post some pics of the headlight switch when you get done
Old Feb 4, 2012 | 10:52 PM
1fastls1ss's Avatar
Well the headlight switch **** ended up to be a little PITA. The **** does not have a clear plastic shell, so the line on the **** does not light up. My solution...I cut out the existing white line on the **** with a hobby knife (which took some time) then took some lexan I had and made a new piece to put in the opening in the **** so light would transfer through.
The next is the same as before in OP, made an opening on the rear side of the **** for the wire, and made a hole in the housing for the wire to feed through.
Then put it all back together.
light off:
and light on:
Old Feb 4, 2012 | 11:09 PM
The Mighty Texan's Avatar
Looks pretty snazzy! I need to do work on mine, for some reason when i did this a couple years ago it keeps shorting out so i need to check my wiring, been too busy to work on it though.
