What paint to paint my FAST intake
budget wise duplicolor works fine. 2 light coats adhesion promoter, 2-3 coats filler primer(sandable primer is optional) depending on how well you sanded it. 3-5 coats paint of your choice, I did 7 coats of clear coat to really give it that powder coated look. All rattle can. The trick is prep work, don't skimp out on sanding. I went 120,220,400,600,then 1000 grit, smooth as can be.
