Sponsored by: DashLynx
camaro no front grille mod question
Old 04-07-2012, 08:19 PM
blackfbird98's Avatar
Default camaro no front grille mod question
hey guys so on my 2000 z i just did the no front grille mod and im just curious as to how some of you who have done the same mod have attached mesh to the bumper??
Old 04-08-2012, 10:52 AM
bad_408_vert's Avatar
its actually a new grille with those mesh inserts.
Click For Link
Old 04-08-2012, 08:40 PM
Double-aught_Z/28's Avatar
Click For Link
Not true. Some of us have put mesh in the air dam holes, without installing any new grill.
@ the OP. Go to Home Depot and buy a piece of mesh gutter guard. It's like $2 for 3 feet. Cut it to be the the shape of the holes, but slightly larger, then stuff it up in there and get it straightened out. I'd suggest you wear leather gloves while you do it, that stuff has sharp edges. As long as you left it big enough, it'll fit snug. I'll try and find pics of mine.
Old 04-08-2012, 09:12 PM
Ok thanks double, def would like to see that, I did end up buying gutter guard
Old 04-09-2012, 10:16 AM
oh ok. learn something new everyday.
Old 04-09-2012, 03:32 PM
Ok here's a few quick pics I snapped. Yes I know the holes from the factory grill are ugly, but so is the front plate, so I'm not worried about them. The mesh is definitely an improvement over seeing the black foam in there. And yes the car is dirty.
Old 04-09-2012, 05:54 PM
Silver98Ztwentyeight's Avatar
Old 04-09-2012, 05:57 PM
I like the black. I may have to hit mine with some plasti-dip or something.
Old 04-09-2012, 08:02 PM
so double, did u literally just stuff it in there so it sticks into the foam? only problem i forsee is if im going fast enough that the mesh just comes loose
Old 04-09-2012, 08:27 PM
Cut it to shape, but a little bigger than the hole, then stuffed it in. Once it's in you can reach down from inside the engine bay to help straighten it out. That's all I did. They fit pretty snug and I've driven plenty fast with them in and they're still there, so yea. Oh and you may wanna tape up your bumper cover around the openings to keep from scratching your paint when you put them in.
Old 04-10-2012, 12:00 AM
ok sounds good, thanks for your help bro
Quick Reply: camaro no front grille mod question
