SINISTER build (update 2/8/13)
#102
Not a whole lot going on lately. But I did do a couple things. I made a hvac block off plate, and radio mount out of plexi glass.
I also managed to get my box wrapped up.
I haven't had a whole lot of time to work on it here lately.
But progress is progress.
#103
It's getting there no need to rush a good thing. Btw, that s2k looks good, even with the vents cut. That gun slinger guy always has something negative to say haha
#104
its amazing how similar of a build you and I are doing..im just now seeing this and we have alot of the same ideas im just not as far into my build as you!! i started on my camaro and had the same ideas but got rid of that and started fresh on a perfect Trans Am!! I got a thread going somewhere lol
BTW...what you going to do for a coolant res??? that gaping hole thats left...is horrible lol
#106
Link to said thread!? Lol
As far as the "gaping hole" you're referring to.. It was welded shut and filled and smoothed out, which I'm still currently working on.
The factory tank was removed, battery moved to trunk, and hole welded shut with a panel and smoothed with body filler.
For a coolant overflow tank, I will have a 90* an fitting off the radiator neck and routed down and under/behind the frame rail where the coolant overflow tank will be mounted.
On to a semi update:
Picked up some corbeau seat rails to mount my seats to once I order them.
Also snagged a satin stretch car cover to help keep the car alot cleaner.
This thing is awesome. Best investment ive made for a while. It will really do well once the car is painted.
Not a big update, but I'm preparing for my daughters birth here in a week or two, so this build will slowly creep along as money and time permits.
Thanks for those still interested. I'm not going to skimp out though.
#107
Thanks!
#109
The cover is a satin stretch cover from jw motoring. Google jw motoring and it will come up. No link. Too lazy for that.
The box itself was built by a friend of mine that actually builds custom boxes and does competition audio himself for a living. It's spec'd for my sub, and the faceplate is cut to fit nicely in the top well. This setup in my car is a digital designs 8" sub, so finding the space to accurately and efficiently do a single ported 12" may be a little harder because a ported box is not just a ported box, it's gotta be setup and tuned correctly for the sub/power combo to make the best sound. Ported sounds so much better than sealed though.
#110
I gotta say that engine bay is going to look great when finished, checking out how u cleean the engine bay of the wiring and hiding it all has given me a way of how to do my wiring tuck, keep up the good work.
#111
http://www.shop.jwmotoring.com/produ...&categoryId=16
Thanks for the mention
