Perimeter head FRC's?
Old Apr 4, 2013 | 01:01 AM
98A4SS's Avatar
Question Perimeter head FRC's?
Can I install FRC's from a 97-98 vette on my perimeter bolt heads? I know that they have a cutout for the return line and our fuel rails are returnees, everything I've read says they'll only fit centerbolt heads,but the early ls1 vetted were perimeter bolt and had them.
Old Apr 4, 2013 | 02:11 AM
blackpala96's Avatar
I know its an F-Body, but I put dual fuel line FRC's on my 98. Does the 97-98 Corvette FRC have one or two cuts for the fuel lines? Either way, it doesnt matter and both will work.
Old Apr 4, 2013 | 04:06 AM
98A4SS's Avatar
thanks i had read multiple threads that said the FRC's would only fit 99+ f bodies, and i didnt want to order them if they wouldn't work. and im pretty sure the 97-98 covers have 2 fuel line cutouts 99+ only have 1
Old Apr 4, 2013 | 12:43 PM
PontiacFan's Avatar
Use the 2-slot covers, I believe you still have the fuel source line & the vapor return line, right? (Two fuel hoses in that area?)
They will fit, but they will not have the lower clips align with the pins on the coils.
They'll still lay down on there & not go anywhere.
Buy the 1997-98 2-slot covers.
# 12556455, Right Side Fuel Rail Cover
# 12559261, Left Side Fuel Rail Cover
Old Apr 4, 2013 | 03:04 PM
98A4SS's Avatar
Thanks Pontiacfan, that's what I needed to know, wasn't sure if they'd stay put
Old Apr 4, 2013 | 09:54 PM
Mr. Trick's Avatar
97/8 corvettes have one fuel cut. Fbody use frc's with two fuel cuts
