Gauge cluster LED's
Old Jul 20, 2013 | 05:21 PM
2QuikTA's Avatar
Default Gauge cluster LED's
Need to finish up my McNord install.....what is the current consensus on the best LED to use? I've seen threads mentioning the WLED-x5/x6/HP5/HP6. What would be the pros/cons on the different ones available?
Old Jul 20, 2013 | 06:49 PM
LT4vert's Avatar
This is the only LED bulb I've used in all the clusters Ive done. The light output is amazing and I have never had one fail. None of superbrightleds.com bulbs have ever failed on me, unlike a lot of others Ive tried.
http://www.superbrightleds.com/morei...edge-base/206/
Old Jul 20, 2013 | 10:16 PM
sjsingle1's Avatar
^^^ yes.......same here..............in red
Old Jul 31, 2013 | 12:17 PM
2QuikTA's Avatar
Got the LED's in. I was nervous what the color would be, but they're awesome! Only problem was the turn signal arrows don't just show the arrow, there is a circle of green light around the arrows. The stock bulbs work as I'd like but of course they are not green, so I'd like to find some green bulbs. Anybody know where I can get green 161 bulbs? As far as I could see, superbright only sells LED.
Old Jul 31, 2013 | 12:59 PM
Sommer86's Avatar
Here is the write up I did for our McNord gauges. 6LE endorses these LEDs for great color and spreading of the light. Since these do not have a direct LED light output on top, there will be no hotspots behind the gauges to look cheap.
http://6litereaterdesigns.com/forum/...p?topic=1077.0
Old Jul 31, 2013 | 01:11 PM
Sommer86's Avatar
It's weird you got a circle around your turn signals. I didn't, and I used a green LED.
