Installing Dash Pad/Crash Pad any tips?
Hi guys, I'll be installing a dash pad on my 1995 Camaro and was wondering if there is any special way in installing the new one..The old one came out in bits so, It's off already. I also have the Pillars removed. Any advice on installing would be a great help.
thanks.
thanks.
It goes in and out one way. Go to the right of the pad and loosen then loosen all other tabs below.After that you will swivel it out by using the right side and pulling it toward you and it will pop right out.Do not try taking it out on the driver side or installing it driver side first.Do all from right side passanger side.
