93-97 ( projector headlight ) not mounted projectors
ok i have never seen anyone make it this far heard a lot of talk but, talk is talk. an this is what i got so far i will update vids on here from youtube as i go. input welcome good or bad i like to hear ideals. i hated the bls set up i mean talk about a let down. ive made a whole headlight frx projectors. an going for a tron look. i have ccfl rings an a ton of leds. next update well have the leds.
the projector is adjustable in the housing. the housing it self is not. fiberglass housing plexiglass shroud an yes a uv blend plexiglass lens (cover) there will be a clear lens cover. the housing will be frenched sunk in alot will not look like the gt covers at all.
sorry my car is tore down for painting so nothing is mounted solid. getting new bumpers an hood. stock ss hood an would love to get a 6le front bumper just cant bring myself to drop 700 on a bumper. i may just mod a stock bumper but thats a nother thread. so this is a full on mod to the car if you do this you can not go back to stock lighting. so any way heres what i got going on. removing rust, t-top conversion, paint, an the headlights duh. give you look at them mounted.
Yeah i know tons of people love the bls kit. Im not knocking his product at all im sure its really great but. I had a set up like that. I made them in one day very easy with the mini's. Better fx-r's wont fit inside the stock housing location. The fxr has bettter lighting at night. the s2000 are the best but there is no way to get to fit. If you like the stock look of the squares their great. This is only my opion just dont like the look in the day time. the stock lamps look better. i wanted a (headlight) an yes i wanted to be differnt.
well i have 6 projectors an all came with clear lens an a bulb spacer. I have never tried to mod them ive heard bending the shield to sharpen the blue cut off an space the lens to get a thicker blue. What ideals have you tried.
He has the FXR
Try adding a small washer on each of the 4 screws that hold the lens to the housing, should sharpen the cutoff. Try it with and without the bulb spacer.
Fx-r clear lens bulb spacer 55watt 6000k bulbs and ballast 8000k ccfl 400mm inverter [IMG]http://i818.photobucket.com/albums/zz101/Liljohnclothier/IMG_6827600657244_zps55df3ad8.jpg[IMG] with out bulb spacer [IMG]http://i818.photobucket.com/albums/zz101/Liljohnclothier/IMG00053-20110311-2339_zpsea0f5bf7.jpg[IMG] with bulb spacer
Well have been working 12s an have only worked on the lights about 15 minutes a day. but the lens mold is getting finale touches almost done video coming soon.
