Z28 shifter knob from WS6 store doesn't screw into Hurst Chrome Stick shifter.
Z28 shifter **** from WS6 store doesn't screw into Hurst Chrome Stick shifter.
I just bought this Z28 shifter **** from WS6 store.
http://www.ws6project.com/user_stor/...ar-shift-****/
However the it doens't screw onto my hurst chrome stick stifter #538-7201
It's too large.
Is there an adapter so I can make it fit my hurst shifter.
It's too large.
A little bit of 'searching', I found this info, ...
http://www.jegs.com/i/Hurst/530/538-7201/10002/-1
Shows that is a 3/8"-16 thread.
https://ls1tech.com/forums/manual-tr...it-few-qs.html
M16 x 1.5 thread for a stock Hurst shifter
https://ls1tech.com/forums/manual-tr...-question.html
https://ls1tech.com/forums/manual-transmission-14/
So you bought a **** that will fit a stock shift lever, & you have an aftermarket shift lever with a different thread.
Now, go back to work & find the right ****, ..., or a different shift lever.
Some more searching, & I may find it before you, ...
It's too large.
It's too large.
https://speeddawg.com/shift-****-adapters
These guys will have exactly what you need to make it work. I had that same problem with mine. Just get the adapter kit with the thread size you need.
16mmx1.5 o.d. by 3/8"-16 i.d.
https://speeddawg.com/shift-****-ada...-adapter-kit-4
