Red LED interior lights always on?????
Hello everyone I recently wanted to switch my interior lights over to led and after seeing a member put red leds in I was sold. So I converted my dome light and the 2 lights in my rear view mirror but noticed something odd. After I had closed my doors and allowed my lights to turn "off" I noticed they were in fact just still slightly illuminated. Has anyone else had this problem? My car has always drained the battery faster than i thought it should and I'm wondering if this was the culprit. Attached is 43mm 212-2 12-smd-3528 rigid loop (I attached 2 of them together for more dome light) from amazon after they are supposed to be off.
So when you say residual power, does that mean it isn't actively draining the battery? I've had some battery issues lately (maybe 2 months ago) but the LEDs have been installed for half a year now.
I wrote the wrong thing above, didnt mean to write diode. Its a resistor you need to use. 1 leg to positive and one leg to negative in the bulb socket. A 1K ohm 1/4 watt resistor should work fine. The resistor mimics the load of an incandescent bulb and will get rid of the glow when the lights are turned off.
Douchebag On The Tree
No, its not draining the battery at all. The leds are responding to a very low amount of milliamps that is always left in the line. You never noticed it before because that small amount of mA is not enough to do anything to a incandescent bulb. LED's are really sensitive and can be very dimly lit with just a couple milliamps. The power left in the line will typically dissipate after an hour or so. Its normal and no indication of a problem.
Just to give you an idea
Well thank you all for the quick informative responses. Do you think just leaving them alone will cause reduced lifespan of my leds? I had a heck of a time just getting the bulbs into the mirrors, the dome light would be easy tho. If it doesn't I'd rather just leave it alone. I don't mind it now that I know nothing is wrong.
its normal. i wired some custom leds up for my interior light by the hatch. they stay on very dim when theres no power. its some kind of residual voltage in the circuit. its harmless though. mine have been in there for like 5 years with no isssue.
