New Racing Seats Installed in 02 WS6 Last week I finished upgrading my Suspension, Wheels and Brakes. This week I replaced my aging seats. http://i62.tinypic.com/33ni7ae.jpg Pulled the stock seats. Quick 3 minutes to remove. $2.00 in change richer.:cheers: http://i60.tinypic.com/izail5.jpg Installed the universal bracket for Firebirds/TA's. Had to drill extra holes in the passenger side. Wanted it an extra 1" further back. http://i61.tinypic.com/2j4dqoz.jpg This week I replaced my seats. The stock seats with brackets weighted in at approx. 48 lbs each. New seats with bracket 30 lbs. each. http://i57.tinypic.com/30at3de.jpg http://i61.tinypic.com/8vrfdg.jpg I still have to order leather pieces with the red stitching to make it look better, but thats next pay day. http://i57.tinypic.com/2wp6l1j.jpg |
Nice, what seats are those and what brackets did you use? it looks like everything went in pretty damn smoothly |
what seats are those? They're SEXY. I like 'em. |
Send me a PM if you want to know what they are or at least where they come from. They don't' really have a name. |
look nice , what are you going to do for a seatbelt holder? |
PM sent. They kind of look like my Jegs/Summit ones, but nicer. |
Originally Posted by ramairetransam
(Post 18678380)
look nice , what are you going to do for a seatbelt holder? http://6litereaterdesigns.com/store/...roducts_id=166 What the Z28's seats do with it. I plan on adding 5 pt harnesses soon to fix this, but I'd like to the the roll cage in first. |
6LE makes a harness bar too if you didn't want to invest in a full roll cage. I still want a harness but I'm not going the full roll cage route so that's another option to consider. |
It's amazing the difference seats make. I threw in a pair of ebay $250 cloth recliners with wannabee harnesses. (didn't install the harnesses) EVERYONE was commenting on my "drag" seats, and how "hard" it makes my car look. I was just tired of sitting on exposed metal. I used a big zip tie to hold the stock seatbelt to the seat like oem so it wouldn't chafe my neck. Cloth seats rule. They're not cold in the winter or hot in the summer, plus the have awesome lateral grip on your ass so road coursing is a breeze. |
Originally Posted by blaine123
(Post 18678461)
Most put the seat belt thru the hole in the seat, but I'm not too sure if I like the way it looks that way. So I found this: http://6litereaterdesigns.com/store/...roducts_id=166 What the Z28's seats do with it. I plan on adding 5 pt harnesses soon to fix this, but I'd like to the the roll cage in first. |
I used the same brackets, you can find them on EBAY and amazon. Think they were called "planted" very thick and a majority of the weight. |
Originally Posted by smitty2919
(Post 18678805)
Please tell me you are not going to buy those $30 straps with 3M tape and stick them to your seats... Same method used from GM recaro racing seats. https://cimg5.ibsrv.net/gimg/ls1tech...b86856d0c9.png I plan on finding a set of black factory seat belts and adding those. Not going to add a roll cage until I replace my rear end. |
those look like the Corbeau Sportline RRS. not a fan of routing the seatbelt through the hole. or putting the 6LE part on either. the ZL1 seatbelt loop looks good and like it belongs there. |
I drive with a racing seat and OEM belt all summer...except when I bolt in a 5pt for autocross days. I route it through the seat hole and deal with it. I'm not bashing the method of securing the belt with a leather loop...it's the 3M "stick on" that seems ghetto. I would sew something on if you ever plan to keep the OEM belt and racing seat. I'm not 100% sure if a 5pt harness is DOT approved for DD use. Like you said, the seat was not expensive so sewing something onto it should not be a big issue. |
(Post 18679401)
Your stock seats looked fine!!! lol. PM'd you for info on the seats. |
also... how comfortable are they? :P |
(Post 18679401)
I drive with a racing seat and OEM belt all summer...except when I bolt in a 5pt for autocross days. I route it through the seat hole and deal with it. I'm not bashing the method of securing the belt with a leather loop...it's the 3M "stick on" that seems ghetto. I would sew something on if you ever plan to keep the OEM belt and racing seat. I'm not 100% sure if a 5pt harness is DOT approved for DD use. Like you said, the seat was not expensive so sewing something onto it should not be a big issue. I have to think about what I'm going to do with my seats and the seatbelt guide. |
Originally Posted by ThoR294
(Post 18680955)
Seems legit. Hopefully the material isn't garbage. Thanks |
© 2024 MH Sub I, LLC dba Internet Brands
