Anyone bought these pieces from 6LE Designs? - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 04-18-2017, 10:03 AM
Question Anyone bought these pieces from 6LE Designs?
I am looking at the front and side pieces and wondering if anyone here has done this:
camar0rs is offline
Old 04-21-2017, 02:14 PM
WIKDLS2's Avatar
You should buy a black TA and put those on
WIKDLS2 is offline
Old 04-21-2017, 02:16 PM
haha yep
camar0rs is offline
Old 04-26-2017, 07:35 PM
02TransAm/Batmobile's Avatar
Do you guys think it would be plausible to purchase a large sheet of ABS plastic, cut the desired shape and paint it black (to hide sanding marks from leveling off cutting plastic)?
02TransAm/Batmobile is online now
Old 04-26-2017, 09:33 PM
blackbyrd's Avatar
One side of that stuff is usually smooth. So it wouldn't be bad to paint it
blackbyrd is offline
Old 04-26-2017, 10:20 PM
I'd hit it with black wrinkle spray paint for texture.
Old 04-26-2017, 10:32 PM
crimson_bird's Avatar
That's how th splitters are made.. though I'm pretty sure they use water jet cutter to cut theirs.. but absolutely doable. A local friend of mine did this... He has some pics around here somewhere
crimson_bird is offline
Old 04-26-2017, 10:50 PM
blackbyrd's Avatar
well one side is already textured atleast thats how the splitter on my gto is
Old 04-27-2017, 07:27 AM
jaxcam02's Avatar
what thickness sheet are you looking to use?
jaxcam02 is online now
Old 04-27-2017, 05:47 PM
On 6LE's site, it says they use 1/4" ABS plastic.
Old 04-29-2017, 09:24 PM
No need to paint to remove sand scratches. Just sand it fine, like 400 grit then hit it all evenly with a heat gun and it will all flow together and look like a perfect smooth edge
MY_2K_Z is offline
Old 05-04-2017, 03:46 AM
I did one myself together with my grandpa. Here is what it looks like
https://ls1tech.com/forums/paint-bod...ut-camaro.html
Putte68 is offline
Old 05-04-2017, 08:42 AM
jaxcam02's Avatar
How easy would it be to bend the abs? Does it become malleable with heat? The only thing I dont like about splitters on the camaro is where it gets close to the wheel well. I hate the straight edge look and I think it would look sweet if you were able to curve it up so it sweeps up to meet the curve of the bumper.
Old 05-05-2017, 09:54 AM
blackbyrd's Avatar
you can heat and shape it pretty easily depending on the thickness. Ive used heat guns to do it but it takes a while to get the right amount of heat to it. Father inlaws frend that runs an upholstry shop use the stuff to build shells for custom interior panels. the use a rosebud attachment on a torch to heat an entire sheet of the stuff and go from there. Ive never watched them do it but I have seen the end result they have made some crazy shapes out of the stuff. the downside is depending on how much you stretch it, it will distort and warp the textrure a bit.
Related Topics
Thread
Forum
Replies
Last Post
BOLO
LT1-LT4 Modifications
39
02-19-2018 08:05 PM
CAMMOTION PERF
Vehicle Classifieds
2
07-20-2017 10:41 AM
BOLO
Gears & Axles
7
10-08-2016 02:36 PM
Mavn
Generation IV Internal Engine
12
09-14-2016 04:25 PM
Quick Reply: Anyone bought these pieces from 6LE Designs?
Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
