Trans Am Fog Light Delete + LED Halo Ring - Page 3 - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 05-25-2017, 02:13 PM
  #41
UNDER PRESSURE MOD
The Alchemist's Avatar
I'm actually going to take my rings, and glue them to the intercooler on my car.
The Alchemist is offline
Old 07-31-2018, 01:04 PM
  #42
Trent Nelson's Avatar
Default Morimoto lights
How did you install/keep the Morimoto's in place and how well have the stayed for you?
Trent Nelson is offline
Old 08-10-2018, 10:54 AM
  #43
M4N14C's Avatar
I tried hot glue, which worked right up until I washed the car. I ended up drilling three small holes in each fog light housing and used small clear zip ties to hold the rings in place. You can't even see the zip ties and they're not going anywhere!
M4N14C is offline
Old 08-10-2018, 11:04 AM
  #44
ThoR294's Avatar
morimotos look much better. nice work
ThoR294 is offline
Old 08-14-2018, 06:05 PM
  #45
I wonder how big the openings are in the bumper of an LS1 camaro fog light opening. Smaller for sure.. just wondering how much smaller. Anybody have any idea ?
EnergyCC is offline
Old 10-21-2018, 06:55 PM
  #46
Casey Tindell's Avatar
Originally Posted by M4N14C View Post
Took out my fog lights when I got MWC lightweight bumper support and never bothered to put them back on. Liked the simplistic look but always felt like it needed something. Buddy of mine hooked me up with some BRIGHT angel eyes he used on his bimmer and after trying them, I really like the look. Pics don't do it justice, at night they're brighter than the original fog lights
Attachment 585892
Attachment 585893
Attachment 585894
Wired them to the fog light switch and also made it on its own circuit so the fog light switch works regardless if the headlights are turned on or off.
Still don't know how to mount them, right now I'm using scotch tape...
would you mind sharing how you wired your fog lights to come on regardless of headlights being on? Thanks in advance
Casey Tindell is offline
Old 10-21-2018, 07:05 PM
  #47
br549's Avatar
I think the whole car looks awesome.
br549 is offline
Old 10-21-2018, 07:10 PM
  #48
Watch out for the lower quality zip ties though. The heat and cold cycles will get to them and eventually they get brittle and fall off..
EnergyCC is offline
Old 10-26-2018, 10:17 AM
  #49
JOHNNY59's Avatar
Why would you not mount them inside the housing? Hot glue and drilling holes with zip ties? Put the halo ring inside for a oem look.
JOHNNY59 is offline
Old 10-27-2018, 08:24 PM
  #50
Phoenix'97's Avatar
I like the fact that now you can have a straight-shot opening to the radiator via the original fog light holes! This would be most beneficial on my application with the hot running LT1. However, I was thinking about just using online specialty LED bulbs to replace my incandescent fog light bulbs. The site I can buy them from can install 30 bright output LEDs on a bulb unit and I imagine the light output would be close to yours with the Morimotos. Also, I would want an opening to my radiator so any air blowing by the fog lights would be used for the radiator.
I will admit, what you have looks cool as hell and is much better being totally rounded off. I would need time to think about it since I am so used to those fog lights on my LT1 Trans Am but again, you can't deny the advantage of having open holes for air to directly cool the radiator.
Phoenix'97 is offline
Old 10-27-2018, 08:43 PM
  #51
Phoenix'97's Avatar
I just did a quick search of the size of the fourth gen Camaro LS1 fog lights and yeah, they are significantly small! I am not sure they even sell a halo fog light for the factory fog lights on your year Camaro, they only sell HID kits but there is a saving grace if you consider it. They do sell specialty LED bulbs that have the same exact sockets as regular incandescent bulbs. This is one option for you to consider.
Another option, try getting a set-up like the LT1 Camaro fog lights, and you might be able to find halo edge fog lights that are bigger in size and give a totally different look to your LS1 Camaro. These are just thoughts and I hope they help you.
Quick Reply: Trans Am Fog Light Delete + LED Halo Ring
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
