LED swap in rear tails, Should I go Red or White?
The Reverse light I'll go with a White LED.
For the other 3 LEDs should I go with White or Red LEDs?
Also, will I need to swap out the hazard flasher?
Copy & Paste Moderator
Wiring isn't the issue. They plug in and use less wattage than the stock incandescent bulbs. However, you'll need to replace the flasher with an electronic "no load' flasher. There are a few different ones for acound $10 - $15.
