Update on T-TOP Divider Rubber Seal (Discontinued)
LS1Tech Administrator
Received 1,483 Likes
Bump, more and more people are saying, both are the same? Whats the verdict? I bought 6 and with shipping i'm out $44 but sure I could sell a few. Mine has had the front seal but never the back seal and never any leaking. I've seen brand new cars back in the day that never had them from the factory ha. Hope this thread keeps going so we can see whats what for everyone envolved.
Devin
Devin
On another note, they are not supposed to stop leaking but they do serve a purpose of covering the seams between the front and rear of the T-tops when they are mated at the T-bar. Otherwise you have that gap where more rain water or snow can work it's way in. I suppose this is why GM designed them and I am sure you can find other ways to produce the same results, either welding metal end caps to perform the same job or using weatherstripping of some sort and getting it shaped to perform the same way as the original end caps.
I have my story and I am sticking to it!
I don’t doubt that they’d work for both & back.
Jus’ sayin’, ..., they may not look exactly like the originals.
i’ll go out to the garage & see if I can locate the spare t-bar center panel that I have, but I think I took the seals off when I had it painted.
Updates to come, ...
i grabbed another set but from someone on ebay had a front and actual rear. the ONLY difference is the part is a little more rounded compared to the front on the lip. Solution line up a few of the fronts and use some scissors to cut the fronts to match the backs and make your own true sets. just a little FYI, does anyone have the thread on how to install them? I'm assuming its pretty simple?
#32
These are the ones I have on my car. The problem was getting them to contour to the T-top trim since they are so stiff being brand new. Another issue is needing adhesive to get them to stick to the T-bar. My job doesn't look as neat and professional as this with the obvious adhesive that squeezed out but it looks pretty close! These were offered from Trans Am Creations USA? Are these reproductions or actual New Old Stock that will run out eventually?
The following users liked this post:
jybravo70 (10-08-2022)
#33
Turns out my dads WS6 didn't need these done, he has never removed his t tops. They have only been off of his car less than a handful of times when I removed them when we would swap cars for a week back in the day. So I suppose that's why. The more you remove your tops, the more you disturb those little trim pieces. And I also can't see these being terribly hard to re produce via 3d printing or a firmer rubber type material. I will attempt such a feat in the future....
#34
Thinking of it, I might see if that t-top bar is still for sale and buy that too, might need another center bar sometime.
#35
These are new old stock, Jeff at TA creations bought all of the fronts GM had left, He sold me 6 and told me that was the limit I could buy (so 3 full sets). He charged me $6 per seal.
@Raleigh TA here on LS1tech, is looking to make copies of the originals.
I have some brand new in a GM bag from Brock's Camaro on Ebay (he sold his last true set to me).
I'd be willing to send my original set off to someone to make reproductions in exchange for 2-3 full sets for myself plus my originals back.
Let me know if anyone is interested.
Devin
Devin
#36
10248550 CAP-RF/WD (This is the front one)
10248551 CAP-RF/WD (This is the rear one)
So these units sold by TACreations are only the 10248551, as the package that has arrived are all identical.
And not that I like to complain, but this again, is still not as the OE GM seals, that were two different profiles.
But what the hell, at least I've got spare parts now, ...
#37
#38
#39
UPDATE!
$40 per set for front and rear, we FINALLY found someone to make them! We is planning to make more items and different hard to find things!
He has 100+ sets in stock!
just got myself 3!
just got myself 3!
