Sponsored by: DashLynx
Driver window banging
Old 12-09-2018, 11:04 AM
Roarin_8's Avatar
Default Driver window banging
Hey guys,
This just happened last night after I put the window all the way down when I was at the ATM, it made a loud bang noise and then banged again and I wasn't touching anything. When I tried to power the window up and down now, it constantly bangs. Anyone knows where on the inside of the door that this needs adjustment now?
Thanks in advance. I'll try to make a vid and post it so you can hear the noise and see the movement.
Old 12-09-2018, 11:39 AM
Roarin_8's Avatar
So many people viewing but no one responding, guest you guys want the vid. I'm at work now so won't be able to post it till tonight.
Old 12-09-2018, 03:06 PM
CamaroRick's Avatar
Maybe the motor regulator rivets came loose, Its common for a replacement regulator to be installed via drilling out the rivets and nut and bolting in place, The nuts could have backed out. If its just the glass rattling there are tension pads that are adjustable / replaceable. They are called glass "anti rattle" good luck!
Old 12-09-2018, 03:22 PM
Roarin_8's Avatar
Yeah that side had the motor replaced using the drill through door method. I hope the nuts didn't back out, I didn't hear anything drop in the door.
Old 12-09-2018, 08:18 PM
Roarin_8's Avatar
Ok here's the video:
Old 12-13-2018, 06:47 PM
LS1121's Avatar
Yea ya probably need to take off the door panel and look inside, probably pretty obvious when you do.
Old 12-14-2018, 10:29 PM
Roarin_8's Avatar
Ok so now have to find the time to do it.
