Help! Wire Mod Complication!
I did the wire mod and shortly after hit a bump, as soon as I did my asr off, brake, & abs inop lights came on. I assume they are loose but they were tight in the first place so how and which ones do I fix? Please help!
1 Post
First thing would be to check your connectors.. Make sure that everything is still connected..
Check the grounds first off. You probably relocated one or more during the mod.
If that's not it, you know what to do - take it back apart, make sure the harnesses are all connected properly and that there are no wires with insulation rubbed through.
Here are the pinouts :
http://www.ls2.com/boggs/controls/connectorsengine.htm
Here's a diagram of the connectors :
http://www.ls2.com/forums/showthread...threadid=83525
If it's not the wiring, a bad EBCM can cause the same symptoms you're describing (the electronic box attached to the brake lines under the hood).
Good luck !
Bad30th
Good luck !
Bad30th
I used the method at the top of the page, I also did relocate both grounds over the wheels down to the hole that the wheel well screws into, could that be it?
