Removing Rear Seats, Seat Belt Problem
Seats are a breeze to break loose..But my problem rests in the shoulder bracket the seat belt goes threw on the back. I had the correct bit and everything..and 2 outta the 4 just stripped instantly. Is there anyway to get the seat belt threw that bracket without removing the brackets? The only thing im thinking is to cut it.
sorry to say, but i doubt those bits from sears will work this time due to all the lock-tight on the screws...i would say either try cutting a slot on the bolt with a dremel so you can use a screw driver, or just completely cut off the bolt...
Originally Posted by jdustu
i think i used a pair of vise grips....i can't remember, but i got them off without cutting anything......
Ive done the same thing. I stripped out my bolts and used vise grips. Worked out great
whew..i got it.. I pretty much just cut a slot in the brackets to get the seat outta the car...grinded a slot into the head of the bolts..and used a flat head and twisted um out. Thanks guys!
