bulbs or lamp
You mean headlights?
They are Lamps/sealed beams.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
The 4th gen Firebird has sealed beam units. The entire glass housing is the bulb. If you want to install HIDs, there are a few different ways to do this. The easiest is to get sealed-beam conversion units that allow the installation of "normal" bulbs. Eurolights (or is it Eurolites) and AutoOptics make them. Although I think AutoOptics is gone. In this case, you can get re-based HID bulbs that will fit in place of standard halogen bulbs. This is not the optimal solution though. The optinal solution would be to go a custom route with actual projectors.
Also, a search sould have answered this question:
https://ls1tech.com/forums/showthrea...&highlight=hid
https://ls1tech.com/forums/showthrea...ight=projector
**https://ls1tech.com/forums/showthrea...&highlight=hid
There is more, but this is what I found quickly.
