Tried putting hood decal on. SUCK!!
![Thumbs down](https://ls1tech.com/forums/images/icons/icon13.gif)
I bought a set of decals from 3rdgendecals and tried to put the first SS hood decal on today. What a major pain in the ***! The bubbles weren't such a problem, it was the creases in the vinyl that would happen if you tried to squeegie them out. I even used some professional spray that I bought from a decal shop to apply them.
Needless to say, it came out looking like ****. I guess I was never meant to be a ricer, because I suck at putting decals on a car.![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Probably have it painted on, I don't want to try the 2nd one they supplied.
do you mean the stinger style ones???
I'm a pro and I couldn't even get them on our friend BlaSSt's car. Tim ended up painting them on for him. The scoop has just too much curve to it.
See ya Sunday
See ya Sunday
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Yup, I didn't even really think about using those decals when I wanted my scoop done. I heard they were just too much of a pain in the ***. So I went with paint and never looked back, I wouldn't have it any other way now.
Originally Posted by SPANKY LS1
Get a small sprayer, put a tablespoon of liquid dishsoap and fill it up with water, spray the hood heavily, keep the area wet/soapy while you are working, the sticker will literally float until you squeegee the liquid/bubbles out.
Shawn
Shawn
Teri, I'd like them painted exactly like BlaSSt's car. Could you PM me a price?
When I work with vinyl at work, I'll spray the surface, then lay the vinyl piece down, then spray the transfer tape like holy hell, position it and let it sit for 5-10 minutes or so, then very lightly squeegie some of the waterout, making sure its perfect, then go back with an actual sqeegie, or yellow bondo spreader and work the rest out, let it sit for a little while again, then remove the transfer tap.
Shawn
Shawn
Are you painting it black Tony?
Originally Posted by ZaneO
People who install the clear bras use a solution of water and Johnson's Baby Shampoo as a slip solution.
I used just an alcohol/water solution on my Blackbird stripes and it worked well ---I taped my stripes down before I wet the area and it made it easier to squeeze the water out
Thats what I did. Only I used professional vinyl decal solution (basically soap/water/alcohol). Still didn't prevent the creases when using the squeegie.
Tony I know how you feel. The 1st time I put on a set of decals on the car They didn't come out good at all. The second set I did I did a lot better. The trick for me was to let the decal sit after I got it where i wanted it. I let the sun evaporate some of the solution. Once I felt it was dry enough I squeegied the water out. I waited so the decal wouldn't float around and move while I was working. Worked a lot better. After 3 sets of decals I've gotten a lot better at it
Originally Posted by Brandon
did you ever get your name on the back done??
Yep just finished. Put some roses on each side too
Thanks for reminding me I have to fix the A on "pontiac" I noticed it was starting to peel
