Halo Headlights, who has them???
Was the wiring difficult to do on these bad boy's!?! If there were any, what problems did you run into, I just bought some and I am installing them on Friday, need any suggestions or help in advance.
The halo's are simple to do. The halo part is just a red and black wire. Tap them into your running lights or fog lights. I used a clip on type that requires no cutting. Is also cool when you lock your doors and the halo's light up. Everything else is like stock. Only problem I had, is the rubber thing around the headlight was not on good and I had to attach it.
Look great after he got it all done though............but he spent a good part of two days getting them to look just the way he wanted them to look.
Copy & Paste Moderator
Why doesnt anyone search?
https://ls1tech.com/forums/showthrea...highlight=halo
(There are more threads that talk about halo lights. I just tried to find the ones relevant to this thread.)
Halo's look good but its best to re glue the rubber around the lens and i had to put some RTV where the halo wires come out.For some reason my lamps fit a little lose TOO... so i had to use a little more RTV .... But for the money you cant go wrong...
