Painting Valve covers...
Not so much a PITA, just a little time consuming if you still have the stock coil brackets. They have to come off first which is the hardest part if you have never removed them. There is 1 or 2 bolts near the firewall that are hard to get out(use a gear wrench). Good thing about it is you can simply throw them away and never fool with them again!! AFter the coil brackets are off the valvecovers are a piece of cake. Unhook the PCV hoses and unbolt 8 bolts(if you have centerbolt covers) and lift them off.
Bryan
parbreak
Bryan
parbreak
