Camaros with true duals I would like to see what the camaros look like from the rear that have true duals dumped at the axle. Ive never really paid attention to what they look like with no pipes back there. |
I have a z with true duals dumped and it looks pretty badass. I think that it obly looks good when the camaro has the ground effects. I will get you pic soon. |
2 threads down..."my car! pics! looky" hehe, theres a pic there. looks better to see turndowns under car or exit at the muffler like the mufflex, I'm not a fan of tips sticking out. |
go to www.LS1sounds.com and click on pics then scroll to where it says true duals. It also shows pics of cutouts. Very good pics over there. |
I'll see if I can get some pics of mine. I think it looks 1000X better w/out tips. I dunno, just kinda gives it a sportier look to me. |
I think no tips looks alot better too. I don't think I'll ever go back to a regular cat back. http://nitrousfedmuscle.com/images/prostars1.jpg |
If only we could get side exits coming through the fender. probably more like through the door cause that can't happen. |
Originally Posted by GM Muscle I think no tips looks alot better too. I don't think I'll ever go back to a regular cat back. http://nitrousfedmuscle.com/images/prostars1.jpg :offtopic: say man, how much harder is it to not scrape that wings west front facia than the stocker gfx, like how much does it hang down at the nose? I likey |
True Duals would be nice but I hate not being able to see tips. Can you tip them? |
yes you can run them all the way back it just has to be under the axle so i would be very low, i have seen it on a car parked at speedtek |
Originally Posted by camarossman88 yes you can run them all the way back it just has to be under the axle so i would be very low, i have seen it on a car parked at speedtek |
You can run true duals over or under the axle. Over is better as far as filament. I personally like the looks and sound of the turn downs with no tips |
Originally Posted by 2MuchRiceMakesMeSick You can run true duals over or under the axle. Over is better as far as filament. I personally like the looks and sound of the turn downs with no tips |
ive heard that only a 2.5'' true dual will fit over axel. and a 3'' dual wont. but i dont get this because most regular single crossflow catback setups are 3'' and fit over the axel on the right side so why not the left too? |
Originally Posted by skippytheloon :offtopic: say man, how much harder is it to not scrape that wings west front facia than the stocker gfx, like how much does it hang down at the nose? I likey Andrew |
here's mine. TSP x-pipe and dyno max bullets. dumped. https://tinypic.com/8yrh3c.jpg https://tinypic.com/8yrhhi.jpg https://tinypic.com/8yrhb7.jpg |
i will post a pic of mine when i get home from school. |
i just think they need something behind the axle if they dont have any ground effects. like Gm Muscle's looks really good but the Silver SS needs something, whether its ground effects or exhaust, it needs one of the two IMO. but hey, what do i know? |
Originally Posted by 97z286speed ive heard that only a 2.5'' true dual will fit over axel. and a 3'' dual wont. but i dont get this because most regular single crossflow catback setups are 3'' and fit over the axel on the right side so why not the left too? 2.5" is just fine tho for a true dual over axle. It's not like you'll have a problem with velocity anyway. |
You can buy an upper panhard like this BMR. And go 3" over the axel http://www.ls1speed.com/catalogimages/PHR004K.jpg Here are some pics of my TD.. http://members.cox.net/tbpayne/TD.jpg http://members.cox.net/tbpayne/TD1.jpg http://members.cox.net/tbpayne/TD2.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
