Need Help Installing FRC'S
Hi I recently purchased A set of Corvette FRC's for my 99 T/A to give it a little flash up under the hood I purchased the correct ones with the dual fuel line slots and I have them cut correctly to fit an f-body(I think from the pictures I used) but I tried to install them today and I got the driver's side one on(with a lot of fighting with it) but no matter what I did I could'nt get the passenger side one on so my question is can anyone give me a step by step process of installing FRC's or a web site that shows how to install them because even if I managed to get both on if they are painted I would scratch them up with out really knowing how to install them. Any and All help would be greatly appreciated Thanks In Advance
Bryan/Parbreak has a nice write-up available on the web, ...
http://www.thecheckeredflagstore.com/frcs_install.php
Also see, ...
http://home.comcast.net/~zeusjr3/FRCs.html
If you've removed the wire bundles from the fuel rail tubes, it'll help.
Also remove the throttle cable bracket on the top/back driver's side of the intake manifold. And make sure the AIR tubes aren't holding them & keeping from setting in the proper place. Also, what have you done with the oil dipstick?
Also see, ...
