looking for some vht nightshade tips so i want to paint my tail lights with vht and want them to be glossy and have no idea what im getting into haha. so my question i guess is how many cans should i get? what do i need to get them glossy? thanks guys |
Originally Posted by 408Maro so i want to paint my tail lights with vht and want them to be glossy and have no idea what im getting into haha. so my question i guess is how many cans should i get? what do i need to get them glossy? thanks guys Go over in LIGHT coats waiting 5-10 min's in between coats, until you reach your desired color / shade. CLEAR coating them is a must after the night shades!! TRUST ME! I actually went and got mine professionally cleared, and they match my paint perfect. http://www.redline-fbody.com/Copperm...l_DSC00930.JPG |
x2 on what he said |
https://ls1tech.com/forums/paint-body-work/447719-vht-nite-shades-write-up-installation-preparation.html In the 'Hall of Fame' above in the 'sticky', ... |
Well the scuffing is not needed. VHT is designed to adhere to your taillights. Read the instructions on the can. Then clear, wet sand & buff. Scuffing could possibly make it stick beter, but I didn't do it & it worked just fine. Just make sure you don't hold the can too close & get runs. |
I was also told scuffing is not necessary. |
I sanded mine down smooth first to get rid of all that lettering. |
Originally Posted by NOBR8KSS I sanded mine down smooth first to get rid of all that lettering. Here is a pic of mine. I haven't wet sanded them yet, but will be done this week. Don't mind the part you can see light through. It only shows b/c of the time of day & angle. When lookin straight on in person they are both black, but you can still see when the brakes are applied. http://i21.photobucket.com/albums/b2...6/P6060004.jpg |
Originally Posted by BIG_MIKE2005 Well the scuffing is not needed. VHT is designed to adhere to your taillights. Read the instructions on the can. Then clear, wet sand & buff. Scuffing could possibly make it stick beter, but I didn't do it & it worked just fine. Just make sure you don't hold the can too close & get runs. |
I used Duplicolor Truck/SUV automotive clear coat. I applied (5) coats to allow room for wet sanding. I'm gonna use 2000 grit & see how it looks. Then just wash the car & buff like normal. It should shine like the rest of the car. Make sure when wet sanding not to make swirls. Only go side to side & try not to push too hard. Your just tryin to smooth the surface. And use plenty of water. |
Originally Posted by BIG_MIKE2005 I used Duplicolor Truck/SUV automotive clear coat. I applied (5) coats to allow room for wet sanding. I'm gonna use 2000 grit & see how it looks. Then just wash the car & buff like normal. It should shine like the rest of the car. Make sure when wet sanding not to make swirls. Only go side to side & try not to push too hard. Your just tryin to smooth the surface. And use plenty of water. |
© 2024 MH Sub I, LLC dba Internet Brands
