Coil Relocation Kits: Which one?
A. Under the cowl
B. On the fenderwell by the shock tower mounts
C. On top of the fuel rails
D. Below the headers
Appearance-wise, I like D. below the headers, because it totally gets them out of eyesight and does the best job of cleaning up the engine bay.
Cost aside, post up what your thoughts are for this mod and where the coils should be relocated. FYI, I really want to add some nice highly polished or custom painted valve covers.
Thanks.
That way the stock coil harnesses hook right up. You don't need to cut/splice harness wires like you would if relocating to any of the other locations. ~Joshua
Check out Chrome & Performance or Thunder Racing for the under cowl versions.
Mine is basically a copy of the Thunder kit that improves on the bracket design. With just one bolt you can have the whole brick out of the car in 5 minutes.
Plus, mine comes with detailed install instructions, and you can get the two tools that make the install much easier. The Thunder kit has no instructions or tools.
The only downside to my kit is that the spark plug wires are not included. I have the part numbers in the Summit catalogue depending on what brand (MSD,Taylor,Accel) and color.
