This is for you Lt1 guys
Sanded the plastic with 400 grit
Duplicolor spray can high-build primer x 2 coats
Sanded with 800 grit
Duplicolor spray can gloss black x 2 coats black
Duplicolor spray can clear x 2 coat
Very lightly wet sanded 800 grit (I sanded to far, and had to repaint it)
Sanded 1000 grit
Used 3m rubbing compound and rubbed with a soft towel
Rubbed the fine scratches out with my fingers and rubbing compound
Probably an hour worth of sanding, paint and buffing and 2 hour paint dry time.
This is achievable with rattle can paint and a polishing towel:
and from a while ago, all rattle can and rubbing compound and a towel:
I'm about to pick up a $500 beater car. I'm gonna try to paint the entire car with duplicolor rattle can paint.
Sanded 1000 grit
That came out really nice. Just out of curiosity, when you did your inner fenderwells what did you use? Clearcoat? Basecoat/clearcoat? High gloss enamel?
You should do the wire mod next.
Thanks. I had to ask because I wasn't sure whether you were talking about the fuse box and power steering reservoir in the description or had the fenderwells included in that.
