Halo Headlight Question
I just received some halo headlights I purchased on here and I noticed that the housings are the same. One of the housings on the halo headlights has a broken mounting tab, so I was wondering if anyone has switched over the halo trim and lense to a stock housing. It looks like it is possible, but I'm not sure. It seems that it is the only way to remedy the situation.
Also is there anywhere that sells just the halo rings themselves. One of them won't light up so I'll have to replace it.
Any info on the matter would be appreciated.
Thanks.
Thanks.
The stock mounts and the halo mounts should be the same.
I don't believe the rings are sold anywhere but if you send it in we can do it, just PM me if you are interested.
-Nathan
-Nathan
I recognized that the brackets and mounting points are the same, but the actual mount on the headlight, to where the bracket attaches to is broken. So if I mount them, they will move around a bit.
I'm asking about the halo trim, the part that is black/chrome that gives the illusion of 3 separate housings instead of 2 like the stock headlight. Can it be changed over to a stock housing?
Thanks but the halo rings seem to be more expensive than the halo lights themselves. For that kind of money, I'd be better off sending them to led gauges.
