New Interceptor gauge is in... (pic)
#62
for me it was for the timing, manifold pressure and o2 mV readings. I diagnosed a couple bad o2's on my car by watching the readings. Also, I love being able to scan a code if one pops up and reset it without heading to an autozone or borrowing someones tool. The record function is also really nice because I can view the parameters after the run down the strip. It doesn't do everything but its a really nice piece to have.
-Brian
-Brian
#63
Originally Posted by Blackbirdws6
mine is a 97. Pretty sure the only requirement is thats its an OBD-II car however I do not know if it will give you every parameter that is available. For instance, I can view timing but not knock retard.
-Brian
-Brian
thanks for answering my questions
john
#65
Originally Posted by firehawk618
I just got a dual set of the gauges. Must say they're awesome.
I am NOT able to get Knock retard just timing...everyone else have this same issue?
#68
Originally Posted by slow1999blackz28
i went to the website and that thing is cool as **** although i wouldnt spend that much money its awesome
Seems foolish to me.
#70
Is there any way you can post up pictures of the back of the faceplate that just 'snaps into place?'
Also, with the capability to read analog signals, can you add an oil temperature sender to the engine/oil which could then be picked up by the gauge? I read through the user manual and saw that they do sell a connector to read a few other parameters, but it's kinda pricey.
#71
Originally Posted by Tram
Man, this thing is friggin sweet!
Does anyone make a 1 - guage pod for the pillar?
Give new era performance a call, they are a site sponsor, I called them when I ordered my interceptor guage and single pod. Great people to deal with.
#72
#77
One last question:
Does the gauge read the REAL water temperature, or does it stay fixed within a certain temp range (just like the stock water temp gauge)?
#78
Brismo the Grave digger.
This gauge is awesome, i cant wait to get mine! And its cheap to. Imagine how much it would cost if you bought a seperate gauge for each function this single gauge shows. Big money, and it would look stupid having 20 gauges in your car. so $230 brand spankin new is F'ing cheap!! And these go for about $180 second hand.
Has anyone tapped into the analog feature of this gauge to show oil pressure/oil temp?
