LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Appearance & Detailing (https://ls1tech.com/forums/appearance-detailing-18/)
-   -   Need some help with LED's (https://ls1tech.com/forums/appearance-detailing/680983-need-some-help-leds.html)
02pewterZ Mar 22, 2007 12:51 PM
I am trying to replace the bulbs over the window and door lock switches, and I can't remove the old bulb. Is there some secret to getting it out?
Transamin00 Mar 22, 2007 12:52 PM
i drilled mine out, then just glued the led in. i just made sure that the drill bit i was using wasnt bigger then the led.
02pewterZ Mar 22, 2007 01:36 PM
Is there any other way rather than drilling. I bought the #74 bulbs that should be just a plug in.
King James Mar 22, 2007 02:12 PM
I just used a pair of pliers and broke the glass of the bulb. Then I grabbed the insides of the bulb and pulled it out. Sounds kind of destructive but it worked great and didn't break the housing or anything.
bjamick Mar 22, 2007 02:21 PM
Ya ive heard that the old bulb will break but just make sure and get all the old pieces out and you will be fine. ;)
Brian2006 Mar 22, 2007 02:32 PM
The ones on the door will just twist and turn out while the HVAC, shifter leds, etc. you need to pull out with needle nose pliars. Sometimes the whole thing will come out sometimes it won't. If it busts then grab the filaments with your needle nose pliers and pull the base out.
I have even used a mouse pad to get good grip of the bulb to pull them out too. Seems to work.
02pewterZ Mar 22, 2007 02:40 PM
Thanks, that worked.
© 2026 MH Sub I, LLC dba Internet Brands
