Door Panel Crack Repair
Has anyone had any luck with the repair of the door panel cracks. I found a thread on another LS site where the author used #4 machine screws, washer, & nut in an oval hole to allow the panel to flex. He also removed all but one of the factory installed staples. After radiusing the crack he used JB weld w/ some plastic as backing. I used two-part urthane epoxy and #6 machine screws. Waiting on the epoxy to set then trial fit the door panel. Hope the #6 screw are not too big.
https://ls1tech.com/forums/pontiac-firebird-1967-2002/440767-cracked-interior-door-panel-don-t-quote-pics.html
what ur lookin for is in this sticky
Rocky,
I'm currently working nights for this week and haven't been able to finish the mod. I have the panels expoxied and screws in the passenger side panel. I'm hoping to be done on this assignment by the weekend. With luck, I should be able to trial fit everything and get some answers back to you. I did notice that the vinyl repair kit doesn't hide the crack well in the plastic. It would not adhear to the plastic. Several threads mention using the vinyl/leather repair kit to match the texture and hide the crack on the interior. Not sure how they got it to work, but it wouldn't for me.
I actually did this to my WS6 and I too, used bolts. But mine were #4-40 that I cut down. I was just wondering if you've had any negative affects from the screws. I haven't yet, and don't expect to, but I thought I'd ask anyway. I do, however, think that this is a permanent fix and that no more cracking will occur, but only time will tell.
I hadn't seen the other site that shows the screws. Have a link for it?
Update:
I found the link. http://www.ls2.com/forums/showthread...hreadid=340995
Crazy, I did the EXACT same thing to mine!
Update:
Update:
Update:
Rocky,
I trial fitted the passenger door panel this evening. I raised the window a couple of times. No signs of rubbing with the #6 bolts/nuts. Hopefully this will cure furture cracking.
Dave
Dave
Originally Posted by prince xizor
What do you mean by radiusing the crack?
Dave
