Tail light swap (LT1 -> LS1)
My friend who has a 1997 Camaro has the "LS1" tail lights in them, even though they came factory from the factory with them in 97. I have a 94 Camaro with the LT1 tail lights in them. We both liked eachothers style and wanted to swap them. How do we do this? I've seen it done before so I know its possible. I'm pretty sure its not a direct fit, so what do I need to do?
The bulb harnesses are different, you'll def need to notch out the holes in the back of the LT1 tails, which is pretty easy w/ a dremel. If you want the LT1 tails to light up the entire red area you'll need to run a wire from the middle vacant middle part of the bulb harness w/ a rubber plug to the running light wire (grey wire)...
doing it to my 99 soon, heres a write up some one did
https://ls1tech.com/forums/appearance-detailing/741654-how-ls1-lt1-tailight-wiring-pics.html
