LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Appearance & Detailing (https://ls1tech.com/forums/appearance-detailing-18/)
-   -   when you're doing an engine swap.. (https://ls1tech.com/forums/appearance-detailing/844488-when-youre-doing-engine-swap.html)
JumpInTheFire.com Jan 12, 2008 06:56 PM
like if i have a 3.8. and putting a 5.7 in with the 6speed transmission... can i just drop the engine and trans in.. or do i have to remove the front axel and wheel like this pic:
http://fad2blk.smugmug.com/photos/84169156-M.jpg
fast01z28 Jan 12, 2008 07:30 PM
the engine is easier to remove from the bottom. not sure if you can even remove it from the top.
Brian2006 Jan 12, 2008 07:55 PM
I can't support your question but what in the hell does it have to do with appearance and detailing? May get better luck in the External Engine section
Mike@HSW Jan 12, 2008 08:03 PM
+1....but to answer the question. We drop the motor from the bottom on every single car we work on.
therobman Jan 12, 2008 08:34 PM
im putting mine back in any day weather permtting and out the bottom is the way to go
blackbyrd Jan 12, 2008 09:51 PM
through the bottom is far easier in the long run and i would look in the conversion section might find a few things also check the v6 sites
30thanniversaryz Jan 12, 2008 10:02 PM
We removed my lt1 from the top...granted we had the heads, intake, and headers off, otherwise it came out fine.
HotWhipT/A Jan 12, 2008 10:11 PM
Not really the right section, but its something like 20 bolts and the whole engine/tranny front suspension drop out. It is actually pretty easy. Looks like this:
http://img263.imageshack.us/img263/9...ebay038rt6.jpg
JumpInTheFire.com Jan 12, 2008 11:12 PM
wow
so i'd have to jack the car pretty high then.
i dont understand how the axle/wheels come off with it. how do you disconnect that from the rest of the body. just bolts?
c0ncEpT Jan 13, 2008 01:48 AM
Well you disconnect struts and ball joints and stuff and when you unbolt the K-member the whole thing pretty much comes down with it.
Josh@MASPORT Jan 13, 2008 01:52 AM
6-kmember
4-trans
2bolts/2nuts-passenger strut tower
2bolt/2nuts- driver strut tower
SPECIALIZED STAINLESS Jan 13, 2008 02:21 AM
From the bottom, like everyones already said... It's easy ;)
http://img.photobucket.com/albums/v2...8/P8170194.jpg
Sgt. Spuds Jan 13, 2008 01:27 PM
Yea, six k member bolts, then unbolt the 4 strut mounts under the hood and take the trans cross member off..
You also have to unbolt the pcm and disconnect 3 connections under the passangerside kick panel and pull a short section of wiring into the engine bay and leave the harness attached to the motor..
DirtyBird222 Jan 13, 2008 01:57 PM
removing the six cylinder engine from the not isn't all that hard, i've done it. but going from the bottom would be easier, just doing it at home jacked up like that scares the shit out of me! find a friend with a lift lol
© 2026 MH Sub I, LLC dba Internet Brands
