auto head lights bypass i want to do this but i saw that you can get to it by removing the radio? any one have a better how to? or a step by step write up? i dont want to go under the dash pad |
just pull the radio and there is a little box behind it pull up on the box and unplug the smallest connection going into the box |
you can't miss the box. takes15 mins tops |
dosent that disable, the drl too? |
yea but it if you want them on turn the switch |
thats the only way to do it without going under the dash |
seriously this is the easiest way to do this. you can live wiithout drl |
Its easy to do. Removing the radio is no big deal. I did this and my auto lights are disabled but the DRL's still work. |
what is drl? |
Originally Posted by JumpInTheFire.com
(Post 8663865)
what is drl? |
If I remember correctly, DRL isn't the only thing that fails to function if you mess with the box behind the radio. The best way it to crimp together the two wires going to the light sensor. The system will think its always daytime and not turn on the head lights... check out the sticky.... there is a detailed pic. |
I done mine on my old Z28 the way VIP1 posted. It disables the auto headlights but the parking lights will still be on during the day. You will then have full control of your headlights It took me all of 5 minutes |
I dunno, I've gotten used to the auto lights and I'm actually spoiled with it :lol: |
just pull your e brake up one notch, and your drl won't work at all! |
i want to tap in to the 2 wires to the light sensor. but i was wondering if i could reach the 2 wires by removing the radio |
Originally Posted by SouthBLVD
(Post 8669270)
just pull your e brake up one notch, and your drl won't work at all! If I'm remembering right, just unplugging part of that box on my 2000 made my turn signals not work. I decided to do the solder 2 pins together mod...I didn't want DRL's or auto headlights though. I had them in my truck and it drove me nuts...but GM allows you to disable it in a silverado (just hit the dome override button 4 times fast or something)...don't have that option on the Camaro. |
well because on my 9" my abs and brake light are on all the time. now i remember reading a while ago jumping a wire in the abs fuse block made the abs and brake light go out. and the brake light worked like it should, this was onlu for 98 it said but no one could confirm it |
dont due what post #2 says. unless you dont want the BRAKE light to come on EVER (ie low brake fluid). |
Hell yeh I been wanting to do this I cant stand the auto lights. |
© 2024 MH Sub I, LLC dba Internet Brands
