Ever Rebuilt a tranny? Hard? Is this a good kit?
Restricted User
So im H/C my TA and worried the tranny wont hold up. SO im thinking of rebuilding my tranny with a kit. what are your thoughts on this kit and how hard is it?
I will be running a VIG 3600 if it makes a difference?
http://cgi.ebay.com/ebaymotors/ws/eB...2BSI%26otn%3D4
LS1Tech Sponsor
Well the kit looks to be ok, I will note however that if you have never built a transmission much less a 4l60e you will likely find it a mammoth undertaking , I would not suggest you try this unless you doing it as a learning experience and this is not your daily driver and you have plenty of time to spend on it, You will also need several specialty tools that are not included in this kit. If you doing it this way just to save money you will likely end with as much or more in it as you would just buying a trans from one of the sponsors here,
__________________
Restricted User
I figured rebuilding it would be a pain in the *** or everyone on here would just rebuild their own. lol
SO what would you guys recommend for a Decent Tranny...Im trying to stay around $1000 and only need it to handle H/C ls1 with VIG 3600 stall
Throw some billet 2nd and 4th gears servos in it and a transgo HD2 kit. This is what I ran in mine for 2 years. I had a 5.3 with a cam and a 150 shot and it never gave me any trouble, and I sprayed through the shifts every time. I finally broke it at the LSX shootout when I hooked up on drag radials, but it wound up breaking the output shaft before it burnt any clutches or the band. The clutches, steels, and band all looked like they could have been out of a low mileage tranny and mine had 107,xxx miles on it. By the way throw the 3-4 clutch release springs in the transgo kit away. They actually make 3-4 clutch burnup worse rather than better.
Happens every day. I get these calls all the time. I was working on a 4l80e today that never had a chance. Came in with low line pressure and not working correctly. My tare down guy took it apart last week and was like WTF is this. Mind you he is not a builder but has stripped down many cores. Kind of scary to see what some people charge for and still can sleep at night. Vince
