Pop sound when applying the brakes dropping back to 1st
I have a built auto in the car and it was also run in my last car too. The thing is when I'm applying the brakes and the trans shifts down to 1st there is a sharp "pop" sound from the region of the brake booster or trans dipstick tube.
It can't be replicated when the car is stationary so I can't really suss it. The trans shop say it's nothing to do with the trans but that is the only thing common between the 2 cars so it has to be the trans. What in the build could be causing it?
Something occured to me today. When the car is at a standstill on a hill (like at a red light) if I leave my foot off the brake the trans/ converter takes up the slack to hold the car there but if I apply the brake the converter loosenes up and lets go completely.
Makes me think that the trans and brake booster share a vacuum circuit somewhere that may be causing the pop noise I get. Any one got some ideas because I can't suss it and if brakes are involed it is a concern to take care of. Definately sounds like the trans dipstick purging air or something in the booster when coming to a slow with the brake applied dropping back to 1st.
Any ideas peoples because I'm fresh out?
