LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   tranny won't engage in first help!! (https://ls1tech.com/forums/automatic-transmission/1055478-tranny-wont-engage-first-help.html)
XGthArO86X Jan 27, 2009 05:19 PM
Ok so I got my car back a week ago after hitting a tree. Drove fine. Now the tranny is done I think. I'll be at a light to take off and it won't go just rev then gradually go. And if I sit there and take my foot of the brake it don't move.rev is fine. Just first gear. Is my tranny done? Third gear has been going it's wouldn't shift into 3rd right away. Like try to but not. Help me!!??
performabuilt Jan 27, 2009 05:45 PM
Do you have a check engne light? Whats the fluid look and smell like ?
XGthArO86X Jan 27, 2009 07:05 PM
It's not that dirty smell a lil burnt. Fluid was a lil low half a quart. Filled it it was the same. Idk if it's something easy and I just got it tuned could that do anything? It's the original trans with a shift kit. Cook say 177k but the speedo was off for 4 yes cuz 3.73s
performabuilt Jan 27, 2009 07:33 PM
well i would get it scanned first kinda sounds like limp mode and go from there
XGthArO86X Jan 27, 2009 08:29 PM
What's limp mode? How died it do that? Drove home from work and it was ok dnt no if that is becuz the tranny didn't get hot yet
performabuilt Jan 27, 2009 08:34 PM
limp mode is when the PCM sees a fault and goes into third gear only mode to protect itself and the trans, A quick scan will likely lead you to a quick answer
XGthArO86X Jan 27, 2009 08:40 PM
Ok I'll get it scanned tomorrow at wok and let u know if there is anything
XGthArO86X Jan 27, 2009 09:41 PM
Will the scanner mess up my tune?
sixvi6-camaro Jan 27, 2009 10:15 PM
no. the scanner will not effect the tune at all.
XGthArO86X Jan 28, 2009 12:48 AM
Ok what does it mean if it went into limp mode? What did I do to the car? Went for a drive it was ok. Beat on it a bit it was still ok. Idk why it's working fine now bit it will prob happen on the way to work again.
performabuilt Jan 28, 2009 09:55 AM
Get it scanned and you will have your answer post the codes back up here
XGthArO86X Jan 30, 2009 12:37 PM
p1637 generator I-terminal circuit....thats the code
WTF is that?? lol
XGthArO86X Jan 30, 2009 07:41 PM
anyone know what that code means?
tptransmission Jan 30, 2009 09:54 PM
DTC P1637 = Generator L-Terminal Circuit
"Conditions for Setting the DTC
1) An improper voltage level has been detected on the alternator lamp driver circuit.
2) Above conditions for at least 30 seconds."
Check the generator voltage level, check the signal circuit and generator wiring harness for poor connections, shorts or opens. Next step check the PCM harness for poor connections.
These types of codes tend to put the transmission in default in order to save battery voltage.
© 2026 MH Sub I, LLC dba Internet Brands
