LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   How many RPM's are yall shifting at?? (https://ls1tech.com/forums/automatic-transmission/1059255-how-many-rpms-yall-shifting.html)
z28_YOU_HO Feb 3, 2009 07:18 PM
Right now i have my rev limited set to 6500 Rpms and it shifts around 6200-6400 rpms..Completely stock motor full bolt ons.
Should i kick it back a notch?
Whats everyone else doing on stock motor?
BadBandit69 Feb 3, 2009 09:03 PM
When i was stock internal i was shifting around 6200-6300
01ssreda4 Feb 3, 2009 09:25 PM
my tuner has mine at 6200 shift and 6400 limiter....
edit: stock bottom end with tr224 and PAC beehives.
z28_YOU_HO Feb 3, 2009 09:31 PM
nice.
99_Z28 Feb 4, 2009 07:02 AM
With stock springs, its not really a good idea to rev over 6200. I shift at 6300 with a limiter of 6500 with LS6 springs.
Camaro396 Feb 4, 2009 09:59 AM
Stock bottom end 7200.
JonCR96Z Feb 4, 2009 01:18 PM
6200 rpm stock internals.
nahasapeemapetalon Feb 4, 2009 05:36 PM
6800 stock bottom end
did 6950 a few times
Rod bolts are weak link. Depending on the year car it can vary from a recommended 6500-6800 rpm limit i believe.
DarkFormula Feb 4, 2009 07:37 PM
7000 w/ stock bottom end and a blower. Going on seven years...
© 2026 MH Sub I, LLC dba Internet Brands
