Dipstick problem?
Old Mar 21, 2009 | 12:00 PM
UCABlackChevy's Avatar
Default Dipstick problem?
All right I take religious care of my WS6 and check all fluid levels very often. A couple of weeks ago I checked my trans fluid and it looked to be a little below full. So I added about 8 oz...
Fast forward to yesterday I went to check my trans fluid and it reads at least 6 inches above the full mark. Almost like the fluid that I put in a couple weeks ago got stuck in the dipstick tube somehow.
Does anyone else have a similar experience or any options.
Old Mar 21, 2009 | 02:44 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Was the car running the first time?
Old Mar 21, 2009 | 08:23 PM
forcd ind's Avatar
as said, was the motor running-if it was, do you look at both sides of the stick
sometimes you get a false read on one side, maybe it splashes up the stick or something, but you have to look at both sides, there can be a couple inches diff sometimes
Old Mar 21, 2009 | 09:13 PM
Yes to both, the motor was running and warmed up both times, and I checked both sides of the dipstick.
Old Mar 21, 2009 | 10:55 PM
crzytown69's Avatar
i can never seem to get my level right lol
Old Mar 24, 2009 | 08:18 AM
Is it possible to get the dipstick out without removing the transmission?
Old Mar 24, 2009 | 08:52 AM
crzytown69's Avatar
yea you gotta take the drive shaft and tranny crossmember off and there thould be a 13mm bolt holding the tube to the back of the head you can get with about 3 to 4 feet of extensions.... it comes right out after that....
