Derale pan on 4L80e does anyone have one of their "cooling" pans installed on an 80'. I have one and the damn thing wont fit (hits the filter)... |
i was gonna get one-which filter are you using, the late model one with 4 tits on it, or earlier one that is flat on the bottom if you have the late one, maybe the early one will fit-do they mention anything in the insts. how close is it?-if your using a shift kit w/v/b stiffiner, it makes it tighter, pushes the filter towards the pan |
Using the late model filter... with the 4 tits I think you got it because that is where the pan hits, along with the slightly thicker vlave body plate would do it. Nothing is mentioned but I will check the auto parts stores and atleast look at the earlier filters. |
have been unable to find a flat pan... even at 3 auto stores |
My Derale pan fits fine, but I have a 95 or 96 trans, so it's the earlier design. -Dustin- |
Does your filter have the bumps on it? That has to be the difference.... |
Got it worked out. For future reference, those with 4l80's; regardless of the year of your transmission, you must use the earlier model (flat) filter when using the derale pan. |
© 2024 MH Sub I, LLC dba Internet Brands
